matt.hoy
I am trying to make a Symbol LS4208 BC scanner talk to a Micrologix 1500 LSP through the Ch0 port via ASCII protocol. I have verified the output of the scanner using hyperterminal. I have successfully fed ASCII into the PLC with hyperterminal, but every time I connect the scanner to the PLC, I get garbage data (sometimes nothing). Also, I can scan the same barcode three times, and get three different piles of garbage. I had assumed that because I am getting *something* that the pinout had to be correct. I have been down every other road I can think of. Baud rate, parity, stop bits, # of data bits, CR appending, etc.
Is it possible that I got some of the pinout criss-crossed and that is causing this? The only reason I am even contemplating this is because if each unit works as expected by itself, the only change is the wiring when they are plugged in. I am also a little fuzzy on the whole RX TX CTS RTS stuff. I can't remember if they connect to the same one or do you connect the RX of one to the TX of the other?
HELP!
File attached.
HELP!
File attached.
