RS 5000 programming questions
NSong
Oct 2010
Winnipeg
21
hello all,
Can anyone help me figure out this problem?
I have a subroutine for controlling diverter valves on three levels: 401L, 1401L & 2402L. The control is same for all three levels. The diverter valve of each level has 2 directions. For example, the 401L one has 600L direction and 1401L direction. Each direction has a limit switch indicating the fully open status. Normally, the valve will be fully open within 30 seconds. I used a TOF timer to shut down the motor if the LS wasn't fully open within 30s, and set a switch_not_ok tag. I tried TON timer, OSF, OSR. All seems not working.
The rung 0 to rung 3 of the attached file is my test rungs. Rung 14 to 23 is the typical 401L diverter valve control.
What's wrong with my program? Any suggestion?
Thanks in advance,
Eric
use the ton timer on the same rung as your start bit(which im guessing remains true while your running). put an xio after the start and reference the valve. If the vlave opens itll stop the and reset the timer. use a latched output for the timer finishing and that will indicate the problem with the valve/stop process.
Hi Luke,
Thanks for help. My start bit is a momentary button on the HMI screen. I'll find a way and try first to see if it works or not.
Thanks again,
Eric
Hi Luke,
Thanks again,
Eric
If its momentary you will need to create a seal in rung so that you have reference for the timer to run. Otherwise your timer will reset when that rung is false.
Hi Luke,
Just tested your suggestion. It works.
Any comments about my using of OSF(OSR)? I just start to learn PLC, not quite sure my mistake.
Thanks,
Eric
Eric,
I don't think using an OSF/OSR is bad, but I would question using it when you need retention of the bad condition or when you require an operator to acknowledge that there is an issue. You could use it to latch a bit but then you're creating an extra rung anyways.
Cool to see your project working.
Hello all, I was trying to do some online programming on a AB control logix PLC v20. I added a new function block routine and added in an SCL...
1,986
I'm new to plc programing and any help will be appreciated. I'm working with Allen Bradley 1769-L32E with panel view plus 7. I need to somehow be...
2,644
I have not used function blocks much in Studio 5000. Could someone tell me the advantages compared to the dis-advantages.
1,416
I have a hydraulic linear feed cylinder with feedback on a proportional valve. I use a little math to calculate a user input speed unit to ramp...
2,079
have very little programming experience. I'm taking a basic course at a community college. We use RSLogix5000. Can anyone please tell me what the...
1,410
