RS Linx crashes when opening interface in FTView?
cardosocea
Nov 2016
Fields of corn
2,639
Hello,
I'm trying to add a new PLC shortcut to an existing FTView SE installation (version 8). Everything is running well at the moment.
I navigate to RSLinx Enterprise, double click and it opens. The initial list has a bunch of network devices on it though not the new PLC and it isn't browsing. If I close the Ethernet tree and it starts browsing, the application can't see any PLC at all and crashes.
I then have to close that window, go to my data server and restart the RSLinx enterprise service for everything to get back to normal again.
Any ideas what may be causing this?
I once had an issue with an older version of Linx Enterprise where the configured firmware version did not match (was lower than) a device on the network. This was within FT Gateway environment, not FTView SE, and it did not fully crash. Anyway, it may be something to check.
Hmmm, this is a very likely candidate I think. I have a small window coming up and will give this a go then.
Hi guys, Working on one of my client's systems with SLC processors, earlier today she called me and said she was having comms errors, had a solid...
2,045
I added several topics to an RSLinx Classic Professional (3.70) installation and was unable to add tags from the topics to Historian SE in...
1,787
I had an interesting problem at a customer's site today. He has RSLinx Classic Professional version 2.50.00.20, and is using the Ethernet/IP...
13,887
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
192
Not a PLC question but I need expert help on this. My FactoryTalk stopped communicating with the server its hosted on. I had an error stating...
106
