RS Linx
eebads2391
May 2008
Stockport
112
Hi ,
Installing RS linx 2.20.01 on Windows 7 pro 64 bit
i3 Lenovo laptop
Pop up says
You are running low on system resources
Ease free up some system resources in order to proceed
I got 4gb of memory
Any thoughts ?
Am I just short on memory
Mike
RSLinx Classic 2.20 has been obsolete for at least 15 years.
Ideally, install a modern version of RSLinx Classic. For Windows 7, I would insist on at least version 2.55.
It sounds like there are programs running in the background that are taking up CPU and memory resources. Open the Task Manager (control+alt+delete) the go to "Performance" (Windows 7 might call it something different) it will tell you what percent of the CPU is being used and by what. Assuming the CPU resources being used is above 30/40%, make note of what processes are using the most and see if they can be disabled. If so, in Task Manager go to Start up (again, not sure about Windows 7 but I do know you can change was starts automatically) and disable the processes that don't need to be running in the background. It's worth noting that even programs that get used consistently don't need to be in the startup folder. Most of the time a program does not need to be already running to use it later.
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
22
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
214
Not a PLC question but I need expert help on this. My FactoryTalk stopped communicating with the server its hosted on. I had an error stating...
116
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
239
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
166
