RS Logix 5 Help with PLC-5 Files
Dec 2015
Concord, CA
I am a beginner in this. I have RS Logix 5 installed version 7.10 which I am trying to view a PLC-5 6200 program. I have the files but when I try to open the .AF5 file Logix gives me an error saying it is unable to open this file. I have tried several times even putting all files in same folder etc.:confused: Any help is greatly appreciated!
As you have found, 6200 files are not readable by Logix5. Look in Tools/database for an import utility - it might be somewhere else though.
If you cannot locate an import utility perhaps one of the members here may have one.
I don't have the software on this(my) computer. ( later tonight) So hopefully someone that does will jump in.
I can open the files in Logix 5, but for the DB import it needs OP$. I don't remember what the other files you supplied are for.
Odd, I have tried this and it would fail to open in RS Logix.
On Another note, lets say I edit the program and need to put the new edit in the PLC, how would I go about converting back to 6200 and upload to PLC?
Do you mean download to the PLC? Why would you need 6200 to do this? It's an old DOS program and not a good one at that. I always used ICOM AI 5. Why can't you use RSLogix 5 to do what you need to do?
Hi all Looking for some help please so I was connected to my MicroLogix 1000 threw rslinks had no issue. I download a program now this program...
46
13,108
Just learning about PLCs and self-teaching myself RSLogix 500 with a little MicroLogix 1400 controller. I have a basic understanding of the...
2,404
Sir, Could you please help me? I need to pull up temperature values from RS linx to Micrologix 1000 PLC using modbus. I've been trying for days...
5,989
dear all: we have a automated vehicle which runs on a magnetic tape. we are taking analog input [0 to 10] volts from a reader this has a...
3,693
I have a program with 16 different recipes. We are having problems with pranksters changing some of the settings from the touchscreen and causing...
2,272
