RS Logix 500 uninstall!!!!!!!!
Jezz
Dec 2002
Kendal
399
Hi all,
we are going to get a new laptop :D so we need to uninstall RS Logix 500 I have never done this before and have no idea of the what is going to happen when I uninstall I have the licence disc so no probs there but having never done this I'd like to know what happens when I do this.
Thanks in advance Jezz
:confused:
If you are going to uninstall the activation, put the master disk in the floppy drive. On the master disk, there should be a program called EVMOVE. Run it, and it should move the activation.
As a check, run it a second time, and it should show that the activation exists on the floppy.
Uninstall RS Logix is easy!
Hi Jezz,
look! uninstall RS Logix is very easy, you can uninstall the key or the soft separatly. if you need install the soft in your new laptop, you only need the key licence, is not necesary uninstall the soft of your old laptop.
I think that it's that you are asking!
Santiago
Great so I can remove the key using EVMove and still leave the prog on the old laptop and then if it all goes wrong all I have to do is remove the key from the new one and put it back on the old one..
:D
Jezz
i cannot uninstall RSlogix 500 v9 from laptop. in control panel, remove window stays freezing for days. i tried to reinstall it to get the new...
3,549
Hi Guys , can anybody help me. I am trying to uninstall an old version of logix 500 before I update to latest version. When i run uninstal...
2,340
Hi, I run Windows XP and currently use RsLogix 500 V6.0 and RsLinx Professional. I need to know the steps to move or reset keys, also I need to...
8,868
233
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
92
