RS LOGIX 5000 help
kanav
Feb 2010
mississauga
Hi All,
I am doing a project on the FESTO pressure regulator in which I have to maintain constant output pressure according to the desired set point. Now the SET point have to be controlled by Voltage signals 0-10 V DC. Now I am confused how should I do this project i.e I am confused how should I vary my voltage signals?????
Any help?????????????
More information would be helpful? Like Processor type? Depending on the rack you have, you will need an Analog card Input/Output, once you have configured that, you can use
the scaling functionality within logix to control your FESTO pressure regulator.
I am using COMPACT LOGIX 1769 L32E PROCESSOR...ALSO i AM USINg IQ6XOW4 ANALOG INPUT/ OUTPUT CARD..
Hi, i am a final year student in mechatronics and is doing my project on plc, and using rs logix 5000, the problem that i am having is data types can someone help me on this please, how to assign them?
When you define the Tag, there is a drop down box that allows you to select different Data Types. If you do not specifically select a Data Type, it normally defaults to DINT.
Stu....
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
631
Hi all, Has anyone found a quick way to patch in the functionality of the Windows help files in Windows 10 so it can be utilized in Logix 5000?
632
Hello Everyone, I have tried to access the help function from my RSLogix 5000 but everytime I select a function block on the PLC rung and press...
1,291
I’m working with indirect addressing and trying to make an HMI where each Rectangle Object has a tag of “A[0-127]” with a correlating Push Button...
4,232
I have been tasked to upgrade some SquareD PLCs at our plant. I have done several of these upgrades without any issues. However, I have now met my...
2,456
