RS Logix fatal error in FBD
Ritwik
Jun 2012
Chandrapur
I am new member in this forum. Please regarding following fatal error in RS Logix.
I am getting Fatal Error whenever I am trying to create a new IREF base tag in FBD or when I am trying to copy an existing base tag to an IREF element in any sheet in FBD.
There is no problem in ladder. Even in FBD, if I try to insert any BOR or BAND block, there is no problem. Fatal error is coming only in case of Iref item
Error code is: RXE_A_READY_EXISTS (object already exists and can not be created twice).
Error no: Ox80042003
Thanks,
Ritwik
Welcome to the Forum !
The issue you are describing sounds like a bug in the data handling for IREF blocks in RSLogix 5000 prior to v20.
The error, its causes, and several workarounds are described in the Rockwell Automation Knowledgebase as Article ID # 64462. You need a TechConnect support contract to view that article.
Hi All, I've been pulling my hair out trying to fix this for a few days and need some advice. I have V19.01, v20.05, V21, V24, V30, V31, V32...
420
Howdy Everyone, So recently I started getting a fatal error anytime I open the monitor in a specific program in logix designer error 0x800420b1...
1,134
I've googled and searched for this error but can't see it anywhere. When I try to open this program I get the following. Error 0x8004201d...
3,984
Hello All, I have been getting this fatal error repeatedly when trying to connect to a PLC in our facility. I have never come across this...
1,827
So I installed studio 5000, with logix designer v32. Everything was fine until I decided to enable the Bookmark Toolbar. At first all it did was...
9,588
