RS logix modules are yellow colored
ashu2shreya
Mar 2017
Maharashtra
17
Rs logix 5000 shows yellow colored warning symbol for I/O configuration but PLC get online and run easily. Can you please tell me what is going wrong?
Without knowing more information than you have given, I would suggest that the PLC I/O not responding light is also flashing and the PLC cannot communicate with one or more of your I/O modules.
Go to the properties for each of the model and note the error codes for each of them.
Post the PLC part number, Version of RSlogix, Module part number, module error code and description here.
Hello, working with a test project, encountered such a problem that rslogix5000 does not see the modules, in rslinx I see them, the driver with...
855
Hi everyone, I can't add any modules to the Controllogix backplane and it doesn't matter online or offline. Both is not working. Please see the...
2,990
Hi Guys, I am using rslogix 5000 at work and we have different zones with different PLCs and some of them have devicnet scanners as well which...
2,839
When attempting to add IO modules to the backplane of a Guardlogix controller (5069-L330ERMS), there are only 18 modules from which to select, and...
1,378
Hi Everyone, Would like to ask about something we encountered on our work and would like some advise. We are upgrading a SLC controller to a...
2,469
