RS232/485 to USB converter question
Nora
Jul 2007
12401
Hi-
I am using a Siemens S7-200 PLC which has an RS485 port in its CPU. I use a Siemens PPI converter (485-->232) to communicate with my laptop (dedicated serial port) when I want to download new software into the PLC.
I use this PLC CPU port also to communicate with an RS232 printer, which works fine with the converter cable.
I would like to use a USB printer with this PLC and would like some advice of how to proceed. I use successfully a Belkin
RS232-->USB converter on another (only USB port) laptop, but this converter came with a driver.
From reading the boards here, I gather that the driver "names" or addresses the USB port on my laptop as a serial port.
Does a RS232-->USB converter driver do anything else?
Is it possible to make or purchase a hardware only 232-->USB converter?
What exactly does a RS232-->USB converter do...is it voltage level shifting or complete protocol changeover?
Will it be possible for me to just put a 485-->USB cable in the PLC and it will talk to a USB printer?
Thanks in advance for replies,
Nora
Nora
It won't work, the USB->RS232 converter is not just a signal level converter, it is an active device that requires a power source & the correct instructions to activate and control the RS232 link, these instructions are provided via the driver software that is supplied with the device, the software driver is designed to work with a particular PC operating system - not a PLC.
You could make an RS232 to USB printer converter: using a PC as the interface. You would need some software (possibly a terminal emulator) that echoes the received serial data out to the printer.
regards
Phil
Hi everyone, I need a rs232,422 to 485 cnverter and 8 port re422,485 to usb converter. What brand could you recommend that is tested already...
2,416
i have an device which can support serial (RS485,RS232),CAN protocol . i want to connect it to an existing MIB 1553B bus ,what device will I need...
99
Hello: I have to connect a RS232 Modbus RTU slave that only has Tx, Rx and GND signals to a Modbus RTU master. However, all RS232 to RS485...
238
need to set up to load applications to the PV1000 RS232/DH485 thru a SLC 5/04. Laptop is usin a PCMK to the DH+ on the SLC and the SLC is...
1,778
Hiii, I want to communicate MGate MB3180 to my ML1400 channel0 configuration as my ML1400 as Modbus RTU master. But i need pin configuration for...
1,743
