RS232 9th Bit Interrupt Support In S7
arc
Dec 2004
India
66
  1. Does any one know if S7-300 or S7 400 range of PLCs support 9th Bit Interrupt in their Serial Ports, and how do we take this into account so that data & the application can be on Interrupt based instead of scan based on S7 300 / 400 ?
  2. What would be the cable diagram to support 9th bit configuration?
  3. Any write up such implementation ?
  4. Does DP-RS232 module of Siemens also support this feature over profibus ? (It may need more explanation , but if any one can let me know it would be wonderful) ?
  5. What Industrial Known Serial devices (A small list) are supporting 9th bit Interrupt on RS232 ?
  6. Any Application example or implementation would be of great interest !!
Are my questions making any sense ? Please let me know !!
Thanks for reading and thinking on my behalf!!
Arc
What are you actually trying to do? The S7300/400 PLCs do not have serial ports. Instead, you would have to buy the CP340/341/440/441 cards, in which case you can set up the RS232 any way you want.
I don't know what you mean by making it interrupt based vs scan based. Can you elaborate?
RS 232 9th Bit In S7
Dear S7 Guy,
  1. In some Protocols UART has a 9-bit mode which basically means you can interrupt on each character received, or interrupt only on a character with the 9th bit set. This drastically reduced the interrupting overhead on a multidrop system (in that all bytes without the 9th bit set can be ignored). (described in the serial device)
  2. Planning to Use multiple "DP RS232" on profibus to link up many such serial devices which support 9th Bit interrupt. Can i still use the DP RS232 with such a feature??
  3. The distance from the CPU to all these devices are more than 50Mts and I wish to connect them on Profibus Link Using the Product called "DP-RS232" Converter provided by Siemens.
  4. Not planning to use CP340/341 etc...
  5. I am sorry, may be I did not explain the config in my earlier post.
Regards
Arc
i have an device which can support serial (RS485,RS232),CAN protocol . i want to connect it to an existing MIB 1553B bus ,what device will I need...
99
Hello: I have to connect a RS232 Modbus RTU slave that only has Tx, Rx and GND signals to a Modbus RTU master. However, all RS232 to RS485...
235
Hi to everybody. I need to read the first 12 characters of the message that a barcode reader sends to the ascii card (1734-rs232 ascii) and I...
728
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,557
I'm trying to manually convert a Beijer E200 HMI project onto to a new Mitsubishi GOT gs2107-wtbd. The PLC is a very old A-series AS1CPU and is...
383
