RS232 Mux on PLC 5/ SERIAL PORT
CaspianSage
Jan 2017
Where I Am
128
Have any of you used an RS232 mux on a plc 5 serial port so more then one device can communicate with it with DF1 protocol?
Any idea if it will work decent enough for non critical application?
Thank you.
... I don't think this could work... There would have to be a driver in the plc to talk to the MUX. -- I was thinking backwards...
Thank you.
In my previous life as an A/V integrator I managed to pull of a similar trick with four relays for selecting which device to talk to. Still running like a clockwork, just make sure you have gold plated relays to handle the small currents.
i have an device which can support serial (RS485,RS232),CAN protocol . i want to connect it to an existing MIB 1553B bus ,what device will I need...
104
Hello: I have to connect a RS232 Modbus RTU slave that only has Tx, Rx and GND signals to a Modbus RTU master. However, all RS232 to RS485...
248
Hi to everybody. I need to read the first 12 characters of the message that a barcode reader sends to the ascii card (1734-rs232 ascii) and I...
737
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,571
I'm trying to manually convert a Beijer E200 HMI project onto to a new Mitsubishi GOT gs2107-wtbd. The PLC is a very old A-series AS1CPU and is...
392
