RS232 to Blue tooth
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Has anyone here had any success using an RS232 to Bluetooth device? I would like to connect to an Omron CS1G wirelessly, with my laptop. It is for a robot and trying to connect with a wired connection isn't possible, without the robot running over my cable. Thanks
The question must be if the Omron programming software demand that the serial port is a real port with a real UART, or if a virtual COM port is acceptable.
I have no knowledge about that.
One way to check it could be to use a USB-to-RS232 adapter (which costs next to nothing) and test if it works.
If it does work my guess is that a Bluetooth-to-RS232 gateway will work too.
Hey! Now there's an idea. I already have to go through a RS232 to USB adapter to connect to this device. I could then connect that USB to blue tooth or ethernet wifi module.....I think. Great thought. THanks.
Errr... you are welcome.
(Since the USB-to-RS232 works, I would just go for a Bluetooth-to-RS232).
Anyone every try these? Thinking of maybe using these on an SLC5/04, if RSLinx doesn't protest. There isn't a lot of noise where it will be used...
2,098
i have an device which can support serial (RS485,RS232),CAN protocol . i want to connect it to an existing MIB 1553B bus ,what device will I need...
99
Hello: I have to connect a RS232 Modbus RTU slave that only has Tx, Rx and GND signals to a Modbus RTU master. However, all RS232 to RS485...
238
Hi to everybody. I need to read the first 12 characters of the message that a barcode reader sends to the ascii card (1734-rs232 ascii) and I...
729
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,559
