Rs500 SQO File Question
Rippey574
Dec 2015
Elkhart
26
I am reasonable familiar with with rs500 sequencers (by no means an expert) but this format of addressing the file on a SQO has me stumped..
It is addressed in this format
#N[N7:35]:0
I am use this format
#N7:35
So what has me curious is what the :0 use for?
I have been cruising the Rockwell instruction manuals and they don't seem to address it this format.
It's called "indirect addressing".
If the value of N7:35 is 7 then #N7:0, If the value of N7:35 is 10 then #N10:0
The # is an index or starting point.
"0" is just the first word of that data file.
https://www.google.com/search?rlz=1.....0...1.1.64.psy-ab..0.1.149....0.8cC3t8ALiJ8
Thank you! You quick explanation worked. I was able to find all the data tables this one jumps around to. The pdf went to my collections of quick references too. Now to sort out 5 tables with 165 words, there goes my weekend haha. Plus side its just bit 15 I am interested in the negative decimal should speed all this up.
Hello I am trying to make a program work with a sqo instruction .The process has 5 steps ,and a starting step of zero.There should be 8 sec...
17
1,067
I have upgraded an old RS500 project to Studio 5000, it has thrown multiple errors which I am currently working through. I have looked through...
1,730
I am working on upgrading a system with a ML1500 that uses a 1769-SDN DeviceNet Scanner to a CompactLocix L24ER-QB1B. Due to cost, I need to...
1,406
I have been ask to check if we can have both English and Chinese in the same I/O description text window and rung comments. I could not Chinese to...
1,218
Hi all, Here's an easy one. I've been asked to change a mitsubishi FX plc to a AB1400 using the same program. My customer has emailed me the...
1,629
