RS500 Startup Protection
jthornton
Jul 2002
Poplar Bluff, MO
295
From the help file in RSLogix500
"Startup Protection Fault S:1/9
When this bit is set and power is cycled while the controller is in the REM Run mode, the controller executes the user fault routine prior to the execution of the first scan of your program."
Is this a good thing to do?
Where do you put the user fault routine?
This is also from the help file in RSLogix 500.
Fault Routine S:29
You enter a program file number (3-255) to be used in all recoverable and non-recoverable major errors. Program the ladder logic of your fault routine in the file you specify. Write a 0 value to disable the routine.
Try Publication 1747-RM001C-EN-P for more information. The fault routine is discussed in chapter 11 of this manual.
http://www.ab.com/manuals/
Hello I am trying to make a program work with a sqo instruction .The process has 5 steps ,and a starting step of zero.There should be 8 sec...
17
1,106
I have upgraded an old RS500 project to Studio 5000, it has thrown multiple errors which I am currently working through. I have looked through...
1,741
I am working on upgrading a system with a ML1500 that uses a 1769-SDN DeviceNet Scanner to a CompactLocix L24ER-QB1B. Due to cost, I need to...
1,417
I have been ask to check if we can have both English and Chinese in the same I/O description text window and rung comments. I could not Chinese to...
1,224
Hi all, Here's an easy one. I've been asked to change a mitsubishi FX plc to a AB1400 using the same program. My customer has emailed me the...
1,640
