RS500 wont start RSlinx (quickly)
Patient
Jun 2012
Auckland
50
Just installed RS500 and RSLinx on a new Win7 x64 VM.
When I open RS500 and try and who active a server busy message box appears and rslinx doesn't seem to open. When I do this on RS5000 it works fine. When RSlinx is opened from opening RS5000, RS500 works.
I've read about deleting a harmony file but this didn't work.
Seems that if I wait 5-10 minutes, RSlinx will open correctly. Still there is a massive delay on RSLinx opening where it doesn't happen with RS5000.
I've experienced the same or similar problem, not in a VM, with none of the resolutions fixing it. I just put up with it and don't close RS500 unless I have to.
Had this happen today. Turned off the wireless connection on pc and activations came good, and rs 500 started quick.
Rob.
Check your Factorytalk Activation manager. I bet a remote connection (normally over wireless) is listed first then your local directory is listed second.
Hello I am trying to make a program work with a sqo instruction .The process has 5 steps ,and a starting step of zero.There should be 8 sec...
17
1,053
I have upgraded an old RS500 project to Studio 5000, it has thrown multiple errors which I am currently working through. I have looked through...
1,724
I am working on upgrading a system with a ML1500 that uses a 1769-SDN DeviceNet Scanner to a CompactLocix L24ER-QB1B. Due to cost, I need to...
1,403
I have been ask to check if we can have both English and Chinese in the same I/O description text window and rung comments. I could not Chinese to...
1,212
Hi all, Here's an easy one. I've been asked to change a mitsubishi FX plc to a AB1400 using the same program. My customer has emailed me the...
1,626
