Rs500
LStewart
Apr 2005
Mississippi
95
Could someone tell me or point me in the direction of a comparison between RS500 and RS500 Professional? I would like to know the advantage the professional has over the ...UN professional?
Lori
RSLogix500 Pro version has some extra features that the standard version doesn't. These features are: Custom Graphical monitor, Recipe Monitor, Factory Talk Diagnostics, Edit database Using Excel,Logic Trace (like Back and forward buttons in IE), Source Control Utility and VBA. These features are not very important things and I believe that you can work easily without them. Hopefully this helps you out.
HG
I wouldn't say it's not necessarily worth the money.... But if you are an "end user" instead of a machine builder, then yes.... You'll probably never miss those features. The ability to use excel can be EXTREMELY useful, if you are doing anything reasonably complicated.
Hello I am trying to make a program work with a sqo instruction .The process has 5 steps ,and a starting step of zero.There should be 8 sec...
17
1,092
I have upgraded an old RS500 project to Studio 5000, it has thrown multiple errors which I am currently working through. I have looked through...
1,736
I am working on upgrading a system with a ML1500 that uses a 1769-SDN DeviceNet Scanner to a CompactLocix L24ER-QB1B. Due to cost, I need to...
1,414
I have been ask to check if we can have both English and Chinese in the same I/O description text window and rung comments. I could not Chinese to...
1,221
Hi all, Here's an easy one. I've been asked to change a mitsubishi FX plc to a AB1400 using the same program. My customer has emailed me the...
1,636
