RS_Networx for Ethernet/IP
Joe_WaZoo
Oct 2006
Murphy, TX
301
What is this program RS_Networx for Ethernet/IP used for?
I would like to use other companies products for Ethernet/IP but they are telling me that AB's software does not allow them to create an EDS sheet for the products that RS_Networx for Ethernet/IP can read in. Other company's products work fine on DeviceNet with the use of their EDS sheets but I can't seem to import those on the RS_Networx for Ethernet/IP.
Do any of you use this program? And what is the purpose? Thanks in advance for your guidance.
Joe_WaZoo
It's basically an obsoleted program, as the IO connections, poll rates, data transfer is declared in RS5000 in V13+.
I had some trouble with a third party device dropping connection, & got with the third party & Rockwell to try & solve it.
Rockwell said don't even worry about the RS_Networx, as it was an old program that set up Scanners, & would be of no use. Instead, we used Ethereal & RS5000 to trap, monitor, & diagnose the network.
Incorrect,
Release 8 just came out,
You will use it with 3-rd party Ethernet/IP host devices or RA hosts that have no software support.
Plus this is a good troubleshooting tool
Example: Ethernet/IP communications for Guard PLC with Guard set as scanner.
Yes, ver 8 available for download if you have valid support option
So should I go to the manufacture of the Ethernet/IP device that I am using and ask them for their EDS file now for the RS_Networx program? I should be able to import that file now into RS_Networx.
Thanks,
Joe_WaZoo
Is this device an adapter or scanner?
If this device is adapter, and used with Logix then you will need assembly information for this device.
You will need EDS file in any case to see device in RSLinx
Hi All Is it possible to connect non AB Ethernet devices to a Compactlogix 1769-L35E, without the use of RSnetwork for Ethernet? Thank you
2,157
I am trying to test a motion control product and .eds file in RSNetworx for EtherNet/IP. I am using a CompactLogix L23E QB1B processor, firmware...
5,556
Dear All I want to download ControlNetworx for Ethernet IP (9357-ENETL3). Please suggest a link / website from where i will be able to download...
3,276
Hi guys, I'm currently working on a small project which has a 2 CPU compact logix running on Ethernet into a switch and 1 RSView SE server & 1...
3,875
Are there any real benefits or requirements to using RSNetworx for Ethernet/IP? We're gonna start up a new line in July, and prepare a...
7,296
