RSNetworx for EtherNet/IP - Can't Add Scanner
PMCR
Jul 2005
Philadelphia
62
I am trying to test a motion control product and .eds file in RSNetworx for EtherNet/IP.
I am using a CompactLogix L23E QB1B processor, firmware 17.01.
I am using RSNetworx for EtherNet/IP 7.00.00 (CPR 7).
My difficulties seem to be that I can't figure out how to get a Scanner in the Chassis of the CompactLogix system, and then edit the Scan List. I am used to doing this in RSNetworx for DeviceNet, and I can't figure out what I am doing wrong in the EIP version.
A screen shot of the chassis config in RXNetworx for EtherNet/IP is included.
Is there any specific 'trick' to being able to edit a Scan List?
For Logix-family controllers using EtherNet/IP and ControlNet, all the connection configuration is done in the I/O tree inside RSLogix 5000.
Only DeviceNet requires the use of a Scanlist editor and RSNetworx software.
The scanlist editor in RSNetworx for EtherNet/IP is used only for third party EtherNet/IP scanner devices.
RSNetworx and RSLinx Classic are sensitive to CPR release mis-matches; I strongly recommend RSLinx Classic 2.55, RSNetworx v10, and RSLogix 5000 v17.01 for use together (all CPR9 SR2).
Ken
Thank you very much for your help.
I did have it working through the I/O tree in RSLogix 5000, but I wanted to test the updated .eds file outside of an Omron configuration package.
I completely understand your response, and appreciate the thorough explanation.
Hi All Is it possible to connect non AB Ethernet devices to a Compactlogix 1769-L35E, without the use of RSnetwork for Ethernet? Thank you
2,133
Hi guys, I'm currently working on a small project which has a 2 CPU compact logix running on Ethernet into a switch and 1 RSView SE server & 1...
3,866
Are there any real benefits or requirements to using RSNetworx for Ethernet/IP? We're gonna start up a new line in July, and prepare a...
7,285
I am getting random comm loss (error code 561 i think?) anyway i looked it up and its loss of comm to 2 modules on a controlnet network. The 2...
349
The back story: We have one customer that has some equipment that uses DeviceNet that must remain in place. On those (5) DeviceNet networks they...
894
