RSL5 I/O export tool
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello. I am trying to export my addresses in RSL5 so that I can import them into an RSL5000 v20.04 project. I can't seem to get a CSV file out of the RSL5. Thank you.
Would this accomplish what you are trying to do: Use the RSL5-to-5000 conversion tool to create a scratch 5000 project , then export converted addresses to CSV, and finally import back into the target 5000 project?
Yes, because I (as well as AB Tech Support) can't get my project to convert so I am trying to convert only the tag database.
Oh...Well, if not already suggested by Tech Support:
Maybe try deleting most or all of the ladder files before converting (if all you want is tag creation)?
Check the databases and delete unwanted records before converting?
It does not appear that multi-record cut-and-paste from the database to an external application is supported. I could not find a way.
Good idea! Thank you.
Hello all, I am STILL working on this PLC5 to CLX conversion clean-up. I noticed on one of the PID loops, they have Output Limiting set to "yes"...
2,664
Hello all. After performing an PLC5 to CLX conversion (second time), all went well. On the surface, it appears that my PID's converted kinda sorta...
1,928
Hello, I would like to know if there is a formula or a way of determining what the bit file from an RSL5 will become in RSL5000? For example: I...
1,830
Hello, I recently converted a control system from PLC-5 to ControLogix and have a question please. My discrete IO converted kind of weird and I...
1,549
Hello. I went from RSL5 to RSL5000 (V.20), bit of a nightmare. The RSL5 was uploaded from the PLC-5/40, not a copy with descriptions and address...
1,850
