RSL5 to Logix conversion PID question
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello all. After performing an PLC5 to CLX conversion (second time), all went well. On the surface, it appears that my PID's converted kinda sorta except that all the tagnames are actual addresses, from the PLC5, meaning, all I need to do is change the PID names and addresses to Logix tags. Does this sound about right, to those that have performed this task before? Thank you in advance.
http://www.plctalk.net/qanda/showthread.php?t=108090
The above post mentions Min/Max scales. This may help you out.
Regards,
It does help, some. I noticed in the RSL5 project, it uses bit 13 (.DN) to trigger the PID function. Is this because of the BTW for the PLC5, and not required for the Studio5K? It appears to me that, outside of Min/Max scales you mentioned and some tags created to replace addressing from the RSL5, there really isn't much to making this functionable? I always fear I am over simplifying something. Lol
Hello. I went from RSL5 to RSL5000 (V.20), bit of a nightmare. The RSL5 was uploaded from the PLC-5/40, not a copy with descriptions and address...
1,847
Hello, I would like to know if there is a formula or a way of determining what the bit file from an RSL5 will become in RSL5000? For example: I...
1,825
Hello all, I am STILL working on this PLC5 to CLX conversion clean-up. I noticed on one of the PID loops, they have Output Limiting set to "yes"...
2,660
Hello, I recently converted a control system from PLC-5 to ControLogix and have a question please. My discrete IO converted kind of weird and I...
1,547
Hello. I am trying to export my addresses in RSL5 so that I can import them into an RSL5000 v20.04 project. I can't seem to get a CSV file out of...
2,012
