RSL5000 Forces
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Good day. I have been tasked with finding an issue we are having with a ControLogix controlled system. As I initially inspected the PLC I noticed the Force Enable is lit on the CPU. I went online with the CPU and it shows nothing is currently forced however, forces have been enabled. I am not comfortable just disabling forces yet. If I remember correctly from the PLC Bootcamp, there is a "curve-ball" to forces in the RSL5000. My question here is, is it okay to disable forces, since it shows that nothing is being forced, online? Thank you
If there are no forces in the CPU, you can disable the forces safely.
In RSL5000 when forces are removed one at a time, after the last force is removed, the forces are left enabled, even if there are no forces present.
the question is: "WHAT is telling you that nothing is being forced" ???
I think that the figure below will be helpful - and the little "Find All Forces" gimmick is probably the "curve ball" that you're thinking of ...
Thank you. Your diagram refreshed my memory. I didn't realize after forces are removed that forces enabled would remain. I know when I remove all forces from RSL500 it would automatically switch to forces not enabled, right? Thanks again.
well, sort of kind of, and maybe ...
in an SLC-500 system (or PLC-5) you can't have forces "enabled" unless you have at least one force present ...
but ...
with most MicroLogix systems, the forces are ALWAYS enabled ...
as with everything else PLC related, one size does NOT fit all ...
I am using version V17.01.00 (CPR 9 SR 1) I have a fairly large machine with multiple PIO nodes on an ethernet network. I am getting a flashing...
1,387
Hello, My coworker and I are commissioning a new panel. We have a 1732-AENTR series C remote IO thats Rev 6.1. The project file from a previous...
1,616
Hello all. Yes, I remember well that RSL5k v.20 was plagued with issues however, it used to run on my laptop. After many years of hibernation I...
1,562
Is there are way to set up RSLogix 5000 to start up with a category in the Controller Organizer 'minimized'? For instance, make the Add-On...
1,738
Hello, I recently converted a control system from PLC-5 to ControLogix and have a question please. My discrete IO converted kind of weird and I...
1,547
