wildswing
Another question in my continuing saga of putting together our first CLX system from scratch in-house...
What conventions/standards do you use when you name your IO modules in your IO config?
A couple of OEM installations we have here name their modules by physical location, for instance...
H05_CC6_A10 is...
- a 1794-ACN adapter
- in control cabinet 6
- IO rack/chassis A10
- they then add _## for slot number to identify modules in that chassis, i.e. H05_CC6_A10_01 is an input card in slot 1
Another example (same vender, different machine)...
F11_PLC100 is...
- a 1794-ACN
- in field cabinet 11
- fist node of IO chassis 100 within that cabinet. There's a second F11_110. The last number identifies 100 = inputs, 110 = outputs.
- input module in slot 1 is F11_PLC101, second is _PLC102...
Having a clean slate, I'd prefer not to do it a certain way just because one of our OEM venders does it that way. I'd like to hear from others. Please tell me how you do it and why.
H05_CC6_A10 is...
F11_PLC100 is...
- a 1794-ACN
