Hi all. I have a tag called "SYS_PARAs" which is dimensioned 4,12,36 and I want to move data into specific locations from another tag so I've used a COP function and set the destination as: SYS_PARAs[HMI_WR_SYS_No,HMI_WR_RTE_No,0] but when I float the mouse over the indirect portion of the address, it shows HMI_WR_SYS_No,HMI_WR_RTE_No,0 as one undefined tag. If I insert a space after the commas it shows each component, e.g. "HMI_WR_SYS_No," as the undefined tag and if I insert spaces before and after the commas it identifies the tags ok and checks out when the routine is verified. Is this really the correct format or should I be using more square brackets? I thought that commas were the correct separators, but not with so much fresh air around them! Thanks.
