RsLGX5K I/O Addresses "Where Used" -Availabilty
SNK
May 2004
Toronto, Ontario
885
Hi people,
I have been using RSlGX5K for about since version 8, but I have not really run into this before...
I have to make some I/O modifications, and I for the life of me cannot figure out how to sort the I/O into "What is used/available for useage".
I basically need to add some inputs into existing cards in the program, but I don't see an easy way how to determine what is available, like the Xreference/where used in SLC5 software.
I know that this will be easy, but for some reason it is over my head.....I have used the pull-down menu for sorting tags....but no luck.
(I am using Alias's and other as well, to make it more complicated)
This is what I do - helpful or not.
I go to 'Controller Tags' and scroll down to the actual I/O 'Local etc'.
I right click on an input or output word and select 'Go To Cross Reference'. This gives all the instances of that word and its bits. A little overwhelming.
Then I click on 'Show' and open to 'Reference'. Click on its '+' and you see the list of referenced bits. You should be able to determine unused bits from that. If not it's at least a help.
I asked tech support about this once.
They basically told me that there is no clean way to view the data table usage like there was in RSLogix 5/500.
I was told that they would make a note of it. I hope that they really meant it and that they do add that feature in a future release (but I'm not holding my breath).
Hello everyone, i hope there is someone here who can help me : i have around 10 different PLCs (with different IP addresses) that i need to get...
223
Hello to all, Is it possible to export Codesys symbols to .txt, .csv or .xml in a similar manner like exporting symbol table in STEP 7? For...
155
Hi guys, so I'm using BOOTP/DHCP tool in my virtual machine for setting up an IP addresses for basically everything. My only issue is always with...
384
Hi. I'm doing an upgrade of an old 1400e to a new panel view plus 7 standard using ftv studio v 12,which will be communicating to a slc 5/04 via...
2,664
Trying to find the proper documentation to explain the CC-Link Parameters for Mitsubishi remote I/O. The system I am modifying uses several...
360
