rslinx 2.59.01 and no pass thru
WineryPLC
May 2012
earth
Just wondering if anyone can help.
Awhile ago I was able to use a wireless router (ip) to passthru a 5/05 via channel 1 (dh485) to a 5/03. now I cant... I took my old laptop out with older rslinx and still can.
is there a solution?
Welcome to the Forum !
The SLC-5/05 Ethernet to Serial passthrough feature requires you to enter the IP address of the computer that will be using the passthrough channel.
When you enable Passthrough, you specify a Data Table number to use as the passthrough routing table. It can hold one or more IP addresses; if it's not large enough to add your second PC, you'll have to expand it offline and download to the controller.
The Routing Table is configured in RSLogix 500, under Channel Configuration -> Channel Status -> Routing Table.
Or be sure your new PC uses the same IP address as the old one and passthrough should work as-is.
Yes Ive checked the ip address this happened when I upgraded the linx
I don't understand what you mean by "Checked the IP address"; are you certain you mean the Passthrough Routing Table in RSLogix 500 ?
If the Passthrough Routing Table isn't the problem, I don't have any additional suggestions.
I have 10 ip address's in my routing table, and my ip is one of those. "I checked the the ip's address"
I think it might be the 2.59 wondering if anyone else having that issue
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
63
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
220
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
251
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
179
I need to support some old data collection that is running on Excel, but I need to get it running on LibreOffice. The following statement works...
97
