Rslinx 3.90
You got me curious, and worried, because I had only installed RSLogix 500 v11 on one of our workstations yesterday and it also updated RSLinx Classic from v3.8x to 3.9x. I've just done a quick check to a 5370 CompactLogix L16ER using USB and it showed up OK automatically in RSLinx Classic. However, I've since done a test to a 2715 PanelView 5500 over USB and it will not show up. I had just flashed this terminal last week over USB from this workstation.
I might try a PowerFlex 525 next.
Hmm?
This particular workstation is running Windows 7 Enterprise 32-bit. There is a 32-bit and a 64-bit USB driver package available with RSLinx Classic and the 32-bit package is installed OK. I've also done a repair on it no to avail. The fact it can see the L16ER suggests the driver is working OK.
What troubles are you experiencing?
Regards,
George
I am using it without any problems, but I recall having issues in 3.81 where Somehow 32-bit driver got activated instead of 64 bit.
There is a technote on how to do cleanup and install 64 bit.
But I'm on 32-bit. I don't care about anyone else!
I tried a PowerFlex 525 but forgot it doesn't show under the USB driver in RSLinx Classic. You flash it using the PF52XUSB.EXE utility and I remember now only seeing it under Ethernet in RSLinx Classic, not USB.
Contr_Conn said:
I was no replying to you, this was directed to the original poster
I know that! I was joking as if I am selfishly hijacking widelto's thread.
Geospark said:
...I don't care about anyone else!
AGill said:
Not believable
Get out of my thread! (<<<Joke_02 - cleverly blending the hijacking and selfishness aspects of Joke_01)
I'll have to experiment some more with this issue tomorrow.
G.
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
63
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
220
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
251
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
179
I need to support some old data collection that is running on Excel, but I need to get it running on LibreOffice. The following statement works...
97
