RSLinx and CNB/E Issue
dskohio
Sep 2005
Virginia
106
Forgive me if this question has been addressed before, but a search for CNB/E did not return any answers.
I have RSLINX Ver 2.50.00.02 (CPR7) installed and we have just recieved a new machine with the 1756-CNB/E 10.007 with firmware revision 10.7
I have a working controlnet network, but I cannot use RSLinx to browse the rest of the network through this module. I am connecting into the backplane via a ENBT/A and can see the CNB/E icon and view module properties, but it does not give me a plus sign to the right of the module to expand the controlnet network. If I enter another rack on the network with a CNB/D, and browse for the CNB/E, I can go through and see everything in the rack.
I have installed the CNB/E EDS file: 0001000C00070B00.eds which I downloaded from the AB/Rockwell site. Has anyone else experienced this, or have any suggestions?
I had the same issue a few months ago. Turned out I did not have the correct EDS files for the CNB/E. If you use the EDS Hardware Installation Tool, click on REMOVE, and wait for the list to populate and search for the 1756-CNB. You will then see which EDS files are registered, and hopefully will not find the CNB/E Ver # that you have. Then go back to the EDS file web page and download
Ian
Thanks everyone for the quick reply, especially Control_Conn for pointing out the revision problem. Control_Conn, your link is for the CNBR/E however.
Again thanks for the help, sometimes the easiest mistakes are the hardest to find.
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
34
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
217
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
243
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
169
I need to support some old data collection that is running on Excel, but I need to get it running on LibreOffice. The following statement works...
94
