RSlinx and compactlogix
eababio
Jan 2011
Gaborone
52
I have rslinx version 2.52 and compact logix version 18..11.
When the rslinx can see the compactlogix backplane through ethernet but i am unable to access the IOs through OPC and Rslinx. Is there a version incompatibility?
The current release of RSLinx Classic is version 2.57. It will include support for all modern controllers and network modules, as well as Electronic Data Sheet (EDS) files for those controllers and modules.
You can probably use RSLinx Classic 2.52 if you install the EDS files for the CompactLogix network module, the CompactLogix system backplane, and the CompactLogix controller itself.
Remember that I/O data tables are not preconfigured in ControlLogix and CompactLogix controllers. You need to define the I/O modules in the controller program, and Module-Defined Tags will be created for them in the Controller Tag Database.
Hi all I'm trying to establish communication between a L43 CPU and a PLC of another brand (B&R). At the moment I'm just trying to see...
5,296
I installed a new CompactLogix in a validated environment and installed the EDS file into RSLinx for the HMI (IFIX) to access it using the OPC...
17
6,229
System: I have three testers, each tester having one CompactLogix L35E (rev. 15.3), 4 PowerFlex 700, one Panel View Plus, one Flex I/O and one...
7,537
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
199
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
236
