Rslinx and rslogix 500 errors with Vista buisness
abdou
Apr 2005
Ohio
Hi folks,
I will be very appreciative if someone will lead me to any tip to uninstall RSlinx Classic and Rslogix 500 from a Dell Vista buisness machine, supposeblly going to programs and features and uninstalling them was an easy task with XP, now at first I got the message " an other installtion is in progress, wait till it's done" there was no installtion in progress, now I get this message respectively for RSlinx and RSlogox 500: problem with windows installer package error 1721, internal error 2738.
PS I kept running RSlinx and logix500 in an other XP machine.
Thank you a bunch!! and happy turkey time
The last I heard, neither RSLogix or RSLinx were rated by Rockwell to run on Vista. It may be impossible to un-install them correctly. I would try to recover the key codes (if used) then abandon the programs, by using Explorer to delete the software, then a clean-up program to remove the unused bits from Windows.
Hello, I am new to the industry and was wondering if someone could tell me if there is a way to check the module properties of the SLC500 series...
862
I've created a test program in Micro Starter Lite and attempting to set up communications with the emulator and run the program. In the...
1,581
I have followed instructions for installing RsLinx RsLogix Emulate 500 RsLogix Micro English I have added the driver "EMU500 SLC 500 (DH485)"...
8,824
More & more frequently I am finding I have to stop the Harmony service. Then delete the Harmony file. ( For some reason only 1 file, not 2. Now...
5,034
