RSLinx Application + SoftLogix
tlf30
Apr 2021
Deadhorse Alaska
193
OK, so I am running into an interesting issue.
I just setup SoftLogix v23 on a system for testing, along with Studio 5000 v23.
SoftLogix reconfigured RSLinx to start as a service, and with it running as a service everything is communicating fine.
The issue is that when RSLinx is running as a service I cannot figure out how to open the window to edit the drivers. To do so I stop the SoftLogix service, then stop the RSLinx service, then unchech the "Always launch as a service" option in the RSLinx launch options. After that I can open RSLinx normally. Then I go change the launch options back, and start the service again.
Is there a way to edit RSLinx without doing all that when it is running as a service?
Thanks,
Trevor
As an alternative, remove the Run as a Service option and then manually open RSLinx yourself before launching SoftLogix. With it already open, SoftLogix will be happy, and you can still view/edit drivers as needed.
OG
OG
Interesting, I attempted this but couldn't get the controller slot service to start. I am getting on a plane, but I'll try again later today.
Hello All, I am going to try and lay out my situation as good as I can. Scenario: We have sites in different location across US that's running...
2,952
I am building a new galaxy for a customer and I am trying to test things as I go. All my Ethernet PLCs are OK, but I have a test PLC5 in my...
2,153
Hi, I am using RSLinx Classic V 2.59 running on Windows XP Professional SP2. I am using OPC Test client to connect to RSLInx OPC Server but :-...
4,217
I just installed rslinx oem. I used to have lite. We got OEM so that we can send data to an OPC. I want to run linx as a service but I cant...
4,090
Hi, I have a RSlink Service running in Windows 2003 server. Because of the office network update, I have to reconfigure Ethernet Drive of Rslink...
15,119
