funky_homosapien
- Join Date
- Jun 2005
- Posts
- 4
AB Gurus, I have a problem with RSLinx auto configuring nodes on the wrong driver. I have dual ethernet (2 ethernet networks completely separate with separate subnets) to all AB PLCs (non -redundant PLC-5 and redundant and non-redundant ControlLogix). RSLinx OEM 2.54.00.11 is configured using 2 Ethernet drivers, AB_ETH-1 and AB_ETH-2, (please note that these are not the AB Ethernet IP drivers). Since the addition of the dual processor ControlLogix, RSLinx has auto-configured some of these PLCs 1756-ENBT/A IP addresses on the wrong subnet, augmenting the correct manual configuration. This is particular to the redundant ControlLogix PLC and I can only assume that the 1756-ENBT has the ability to route packets through the backplane. As we always manually configure the nodes, I would like RSLinx to stop auto-configuring the AB_ETH drivers. How do I acheive this?
Thanks, Ross
Thanks, Ross
