RSLinx Classic 2.59 on Remote Desktop
Epy
Jul 2012
no
376
Greetings all,
From where I'm sitting, it looks like RSLinx Classic won't work through a Remote Desktop connection. Is this true? Is there anything I can do to get it to work?
Thanks for your help.
Running on Windows XP Pro 32-bit if that makes a difference.
Greetings all,
What exactly do you mean that it won't work through a Remote Desktop?
Which Remote Desktop are you using, the one built into Windows?
Normally the RSLinx Runs on the PC you are Remoting too, not the PC you are Remoting from.
Stu....
RSLinx Classic's interaction with the desktop is a common problem.
The specifics are complex; the version of RSLinx, the server OS, the client OS, and the remote desktop session credentials are all variables.
The RA Knowledgebase has a fairly complete document describing what works and what doesn't with regard to this software and Remote Desktop:
RA Knowledgebase Article ID 68346 (Access Level: Everyone)
@sthompson: Using Win 7 Pro SP1 64-bit to connect to Win XP Pro SP3 32-bit using Windows' default RDP client/server. When I start the program, nothing appears. RSLINX.EXE is running, but nothing shows. If I am connected in locally to the XP machine (keyboard, mouse, monitor), it works/appears as normal.
@jac: did not work, thanks though.
@Ken: according to that article, I shouldn't be having this problem, yet I am.
Fixed it. On my Win 7 machine, I can run it as a service and also have the application up. I brought up the control panel in the XP machine and disabled the service, then the application came right up. When it was running as a service, the icon was not showing properly in the corner like it does on my Win 7 machine.
Edit: for clarity, I meant to say that on the XP machine, when the service was running, I could not bring up RSLinx at all. I can have both running on my Win 7 machine.
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
224
Hey All, I am sorry to ask this, but i still gotta do it. What happens if I close RS linx? Will it cause network interruption and PLCs will lose...
179
Does anyone know if there is a way to import RSLinx Classic data into FT Linx? We have a quite extensive configuration set up, and it would be...
2,645
Hello, I entered my controller IP address as 192.168.1.100 (Local) for 1769-L33ER. It worked fine until couple month and found the controller kept...
1,151
Hi All, Looking for some clarity regards the relatively recent rebranding of RSLinx Classic. From what I can make out from the RA website and...
2,490
