RSLinx data into Excel. Multiple users viewing the same data
Topaz2008
May 2010
Es***
I have had experience with reading DDE data from RSLinx into excel but I have been asked by a client to generate a sheet with multiple tabs that can reside on a server and allow multiple users to navigate the same sheet.
The problem I am having is understanding how RSLinx would work in this senario. Can all copies of the same sheet access RSLinx data through one instance of RSLinx or will each user need a copy of RSLinx running? My concern with multiple copies of RSLinx running is the amount of duplicate traffic to the PLC.
I am aware that a SCADA system would be better but the client does not have the budget for this.
Has anyone got any ideas they can share?
Create a single spreadsheet that reads data through RSLinx, then create another shared spreadsheet that reads data from the original spreadsheet.
Thanks for the reply. I came to the same conclusion myself about an hour ago. Why I didn't think of it sooner I don't know...
I had to do this in about '05. Seems like (then) I had to add a macro to save the "master" workbook every few minutes, and when you opened the other workbook, you got a snapshot of what was there that had to be refreshed.
I do remember that within days or a week or two at best, it would freeze and I had to restart Excel, sometimes RSLinx too. As a temporary communication aid, it was still worth it.
Hey all I am working a project where we have a vision camera taking readings on three sections of our material. The camera is already interfaced...
2,322
='\\OMK-MAINT-VM01\NDDE$'|[HT_Data_Collection]REAL_Array1[4],L1,C1 Where "OMK-MAINT-VM01 in a VM on the company network [HT_Data_Collection] is...
1,048
I was able to read a tag in excel from a Controllogix PLC using =RSLINK|'Topic_name'!'Item' Am I using DDE or OPC ? How can I write value back...
5,925
Problem: I want to record temperature from a PLC using Excel, with hour intervals. At the end of the week save the file with a different filename...
10,307
We use RSLinx to interface a program which takes specific data from our PLC5 and applies it to specific fields on our enterprise software. We do...
1,766
