rslinx dropping connection
aryautomation
Nov 2006
texas
34
I am connecting to micrologix 1500 with my laptop and connected through USB connection (with serial tp USB convertion cable)
I can stay online for 20-30 seconds and then I get kicked out and get the message of retry or go offline. then I need to configure rslinx and try to go online again.
I am using micrologic 500 programming.
Ant help will be greatly appreciated.
What model of RS-232/USB converter are you using ? Some just aren't any good.
I've spent hundreds of hours online with A-B controllers over my Keyspan/Tripplite USA-19HS. You will find these well recommended here on the Forum.
Even the best converter will suffer if there's a ground loop or noise on the serial cable. Make sure your computer and the PLC are running from the same AC power source, and if there are servo or variable-speed drives around make sure they are well-grounded and their cables well-shielded.
Once a plc is taken off the network and then put back on usually after a day or so we see some tags in that plc come and go within the studio se...
4,125
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
192
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
230
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
156
I need to support some old data collection that is running on Excel, but I need to get it running on LibreOffice. The following statement works...
89
