RSLinx Enterprise Driver
Vada
Mar 2014
Ontario
Hello,
I have an issue with an application I am trying to implement.
We are using a PC to run as an HMI. We installed FTView ME and everything else required for it. However, when we try to run the application it doesn’t link up the tags. ( I know the '.mer' initself works because I tried it already on another computer)
I opened up the application in Studio on the same PC and noticed that it registers the PLC as a “?” Its almost as if it doesn’t have an EDS file. I did in-fact already install it for RSLinx; but as I understand it, FTView uses RSLinx Enterprise, and I don’t know how to add a ‘driver/device’ in the 'device selection tree' so it is available in FTView.
FTView version: 6.10
RSLinx Enterprise version: 5.40 (CPR9 SR 4)
RSLinx version: 2.59
Any help would be greatly appreciated as I am at a loss at this point.
First, make sure communication is good between the PC and the PLC. Try pinging the PLC first, then open up the PLC IP in a browser window to make sure that IP isn't something else.
Now if all that works fine, make sure your shortcut in RSLinx Enterprise to the PLC is still good. Might be better if you redo the shortcut. it's a been a while since I messed with RSLinx Entrprise but that's what I can remember.
Hi All, Dose any one know if it is possible to set a communications from a Logix5573 to Factory Talk View Site edition over the USB connection...
2,009
hello guys, I use the factorytalk se software, as I add the driver into the RSLinx Enterprise, but have the ?before the every driver, Please tell...
5,088
Hi All, Looking for some clarity regards the relatively recent rebranding of RSLinx Classic. From what I can make out from the RA website and...
2,445
Besides a $3,000 license to purchase a RsLinx Gateway License for every remote computer network that I work on. Is there another way to get to a...
2,700
Hi, I'm running FTView v9 on a VM machine. Host win 10 64 bit, virtual win 7 pro. I've come to configure communication on this project (1st...
2,170
