RSLINX lite unrecognized device
MGuenette
Jan 2007
Montreal
134
I have RSLINX lite on one computer here. Everything is working except 2 PLCs. Rslinx says "unrecognized device. It's strange because i can see the others plcs using the same type of connection (1756-ENBT/A). I copied and pasted the EDS file from another computer using RSLinx Classic and it does not work.
Any suggestion?
Martin.
You do have to use the EDS Hardware Installation Tool (Start... RSLinx -> Tools) to register the EDS files with Windows. RSLinx will automatically rename the EDS files, if necessary, and place them into the \RSCOMMON\EDS directory.
Important: Do NOT run the EDS Hardware Installation Tool on EDS files that are already in the \RSCOMMON\EDS directory !! It will mess up the Windows Registry entries. If you're copying and pasting the files from another computer (or downloading them from the Internet), place them in a temporary directory and then run the EDS Hardware Installation Tool.
A neat feature I recently noticed; 1756-ENBT version 4 firmware and RSLinx 2.51 allow you to right-click on the unrecognized -ENBT and upload the EDS file (in .GZ zip format) directly from the module and automatically register it. No Internet access or copy-paste-run-the-utility required.
Thanks for your help guys,
I think that it's the way to do it, but once I "upload" the EDS file downloaded on internet, i'm not able to clic on RSWho. It says to me "Failed to create empty document". But I already restored a backpup...
Martin.
Okay, you've got more than one problem here. The "failed to create empty document" error message can be part of one or more RSLinx and registry problems.
I recommend taking this up with Rockwell Automation Technical Support directly.
OK
i fixed the problem. I found an Hotfix on the web. The technote # is A40145228. After that i used the EDS wizard managment to upload the EDS file properly
thank!
Excellent ! I'm glad you hear you got this working correctly, and I appreciate you posting your success and the method you used to get there.
The current Answer ID number for that Technote is AID# 24388.
I presume that because you cited that particular technote, you're using version 2.41 of RSLinx and meet the other criteria of that issue. I just didn't want to put you through the slow and painful Q&A of "what version, what OS, what error message...." on the Forum.
Again, thanks for the followup !
Hello, Does anyone know if there is a portable version of RSLinx Lite (even an old one)? I am wondering as I am trying to put together some tools...
688
I've created a test program in Micro Starter Lite and attempting to set up communications with the emulator and run the program. In the...
1,581
Trying to communicate to a network using the two mentioned in title. Can't really find a good video on how to do it. If I choose AB_ETH-1 I have...
3,196
I am trying to Install RSLinx Classic Lite on a remote machine so I can use the Clock Sync Tool, But I keep getting this error. Error 1320.The...
8,150
I can find plc in RSlinx lite but when I open Logix RSWho there is nothing there. The driver I added in RSlinx doesnt even show up in Logix RSWho...
5,856
