RSLinx OPC server
tbode
May 2006
Ohio
23
I am using RSLogix 500, RSLinx Gateway 2.43, and RSlogix Emulate 500 for inhouse testing. I need to set up an OPC connection in RSLinx so that I can use Proficy iHistorian/RSLinx OPC Server connection to collect data. If I create a topic under the DDE/OPC menu item and use Cimplicity Plant Edition and its OPC Client to connect to my RSLogix project, the connection shows up in RSLinx as a DDE connection. The RSLinx Online Help is not very helpful.
Anyone know?
"shows up in RSLinx as a DDE connection." Where, precisely, do you see this indication ?
It's probably just an artifact of labeling. RSLinx Classic configures and manages DDE and OPC topics just the same.
If you connected from an OPC Client, be assured that you are making an OPC connection.
You can probably see the same label by connecting using the RSI OPC Test Client.
Hello All, I know it is possibile to access data from a PLC directly to excel using a OPC link through RSLinx...
1,773
Hello All, I am going to try and lay out my situation as good as I can. Scenario: We have sites in different location across US that's running...
2,968
Hey! In my previous queries on how to handle an OPC server like RSLinx in the ArchestrA IDE galaxy, I have succeeded and the answer was to just...
1,832
Hey everyone!. I would like to know how to use a third-party data server other than Wonderware, such as RSLinx server to integrate it into the...
1,593
Hi Experts, I am using Matlab as an OPC DA Client to communicate with AB PLC rslogix5560. I can successfuly read from the PLC but when i try to...
1,574
