RSLinx PLC5 Contrologix Fix32
asterof
May 2007
Califonia
554
Trying to open an old project
It was Fix32 talking to a Contrologix L61
using Rslinx. I can not remember the ABR 7.x OPC driver setup
and something had to be done in Rslinx
So I have a Channel Named Pulpers
I have a Device Named Span
Primary Channel Setup on Pulpers is AB_ETH-1
which is setup in Rslinx ver 2.59
Enabled check box is set
Span Routing Setup is 1756-GTWY
Device Type PLC5
I am getting API calls timed out error
So what do I not remember
Are you using RSLinx Pro with a valid EVRSI or Factory Talk activation? RSLinx without a valid activation works for your Logix programming software, but you must have an activation to work with HMI software.
I suspect TConnolly has got it right. 2.59 will not work with EVRSI activation. It will still run but only in "Lite" mode. You need to have Factory Talk activation to use OPC or DDE. If you cannot change your activation method you will need to go back to a previous version of Linx.
No I am using the FT activation not the EVRSI
I did however install 2.51 using FT Activation
and still it does not seem to talk.
Hello Friends, 1. How can I connect to PLC5/30 via Ethernet (Rslinx)?. I have not worked on PLC5 before. is it same procedure as MicroLogix...
2,189
Hello all, I currently work for a company that is using plc5/40e's. 5 of them in fact 1 per machine. We are currently pulling live data from...
1,513
RSLinx 2.43 has been installed on my computer for months, but now when I try to autoconfigure a DF1 connection to a PLC5 Channel 0, the message...
7,025
I have and A.I.5 software v8.7 and RSLinxLight installed on Win2000 and RSLogix5000. PC is connected to ENET/B module of ControlLogix. PLC5 is...
3,937
Does anyone know of a tutorial or anything for communicating from a PC to an A-B PLC5 without RSLinx over Ethernet? There are many products on the...
5,923
