Mark Whitt
Hello Folks,
I've recently upgraded to RS Studio 5000 V21.00, and need to upgrade the firmware on the L71 to match. But I'm having trouble figuring out how to get ControlFlash (V12) or Logix Designer to navigate to the PLC so I can upgrade the firmware.
The problem is that while RSLinx (V3.73) will show the USB connection and I can drill down to the L71 processor via an Ethernet Connection, the RSWho will not show the USB connection, and all of the Ethernet connections (which go through an ENBT module) show unrecognized device for the ENBT so that I can't expand the chassis. The situation is the same regardless of whether I try to use ControlFlash or just access the processor from the RSWho of Logix Designer.
I'd like to get both options working, but I'm desperate enough to be happy with one or the other.
If anyone can point me in the right direction I'd be very grateful!
