Rslinx Start As Windows Service
Elias
Sep 2004
Coatzacoacos Veracruz Mexico
Hi, i'm Elias Castañeda from Mexico.
I have a problem, I configure RSLinx to start as windows service on Windows NT service pack 6 and set mode to Automatic. Also I configured a NetDDE Service as Automatic.
I develop a Visual Basic Application that try to get some values over the network via NetDDE Protocol, It's work fine while the user is currently logged in, but when the user is not logged in and the CTRL ALT SUPR Screen is activated, the application fails with the following error: Timeout while waiting for DDE response
This machine are in a lock room outside the city and is so dificult that each time when the electrical supply have interruptions we must go to login into windows.
What can i do?
The PC can be set up to do a "Auto Login". Open regedit and go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
and set AutoAdminLogon to 1 and it will automatically log in upon restart
Hope this helps
Or get Powertoys for Windows which will allow you to tweak registry settings thru a GUI
Try this tweak program I use it on my Win 2000 Laptop and have never had a problem with it. It provides a Domain Login under "Network Settings"
For anyone that needs it, the utilities are fine, but sometimes aren't around.
To manually set up auto-logon to Windows NT, 2000, XP, 2003 and above, fire up REGEDIT.EXE from the start menu RUN box, and navigate to the following registry branch:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
Once you are there, create or edit (as needed) the following STRING keys:
DefaultUserName (Accountname to logon)
DefaultPassword (Password for the above account)
DefaultDomainName (Actual domain name to logon to if in domain, Computer name if not)
AutoAdminLogon (Set to a '1' to enable AutoLogon, 0 to disable)
RSLinx EthernetIP Driver is not starting on Windows 7 PC I have an old XP PC and it works there and I am able to upload program - I tried...
2,496
I want to link tags on excel with rslinx classic gateway and anytime i click on the macro, this stuff keeeps on pooping" start rslinx.exe"
1,198
Just installed RS500 and RSLinx on a new Win7 x64 VM. When I open RS500 and try and who active a server busy message box appears and rslinx...
2,780
Once a plc is taken off the network and then put back on usually after a day or so we see some tags in that plc come and go within the studio se...
4,124
Hi Everyone. I am buidling a VB application which uses DDE via RSLinx to communicate to a processor. I would like to start RSLinx minimized and...
13,966
