RSlinx stopped working
Saavedra
Jun 2015
Tijuana
24
So yesterday I tried opening RSLinx, and a message popped up saying:
RSLinx classis communication server has stopped working.
The program stopped working correctly because of a problem. Windows will close the program and will notify you if there is a solution.
I tried opening RSLogix500 and who active from there, but the program is not running at all (not even as a service).
On Monday (2 days ago) it was running perfectly fine, I can´t seem to figure this one out.
Anyone has any idea of what the issue could be?
Thanks.
Using a program such as Windows Exploer, find where the RSLinx program is located on your computer (usually for Windows XP it is in "My Computer, Local Disk (C:\), Program Files, Rockwell Software, RSLinx, RSLinx.exe").
Then you can Open or Run RSLinx directly without going through RSLogix 500. Once your get RSLinx running, you might be able to figure out why it is stopping.
I tried opening RSLinx directly first, but it happened what I stated above, it closes up inmediately. Right now I tried using the .exe file (not using a shortcut), but the same thing happens, a poput window tells me that something is wrong.
Can someone explain me this? RSLinx Classic service is stopped and yet from RSLogix5000 I was able to go online to the PLC. (Screenshot attached)...
5,179
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
211
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
239
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
166
I need to support some old data collection that is running on Excel, but I need to get it running on LibreOffice. The following statement works...
93
