RsLinx unable to drill down to DH+ network
Malcolmt
Dec 2010
Johannesburg
17
Does anyone know what can prevent RsLinx classic being unable to drill down to the DH+ network of a 1756-DHRIO module in a CLG gateway.
I have three pc’s, two work 100%, one refuses to let Rslinx drill down into the DHRIO module, see attached pic.
The PC OS was Xp Prof SP2, I compared to the PC’s which work, they use Xp Prof SP3. SP3 was added and it didn’t solve the problem.
Rslinx Rev is 2.56.00 13 CPR 9 SR2 .
The Ethernet layout is shown in the attachment.
Tried using the IP of a working PC on the problem unit 9 with the good one disconnected ), it didn’t change anything. All PC’s use the Ethernet Devices driver.
I even tried disabling the onboard ethernet port of the PC and use a 3com card, the problem remained the same.
its got me puzzled.
thanks
Malcolm Moorhouse
Hey folks, I'm unable to see my PLC and HMI in my Rslinx classic even though I can ping the PLC and HMI from my laptop. Please I need help on...
3,663
Hi All Whenever i try to change the IP address of a compact logix PLC from RSlinx, this message appears to me "unable to read module's port...
4,418
I'm trying to create a factorytalk 7.0 .mer file in factorytalk ME. As of a few weeks ago this worked fine on my computer and I'm not sure what...
2,646
Hello to all, I encounter this issue "Unable to save RSLinx Enterprise data server information. Would you like to continue creating the runtime...
5,334
Hi i'm fairly new to plc programming. I'm having an issue connecting to a logix5555 plc with an rs232 cable. The linx and logix software has just...
7,163
