RSLogix 500 Activation
wajidcusat
Jan 2013
Bangalore
Dear All,
When I started RSLogix 500 s/w it is getting a pop up message showing that "your product has not been successfully activated" and is working on grace period for 7 days.
Earlier it was getting the message like "Fatal error: Copy protection license could not be acquired".Then I uninstalled and the re installed the s/w .Now it is getting the above message.Lic file I could see in the activation folder .Checked in activation manager for the path ,which is correct.
Also it is showing that license expires on 31 jan 2012
Please help me in this
Regards
Wajid
If thats the case then there is a good chance that you will have to call Rockwell and get a new activation. Sounds like yours is expired.
Product activation does not "expire", once you've got it, it persists.
What "expires" is your access to unpaid support, software updates, and the knowledgebase, etc.
The only other thing is what type of license to you have? Did you purchase the software or are you using one of their "toolkits" that allows access to all the software. These do expire every year.
So your license to use the toolkit expired two years ago. You need to contact your vendor to have it renewed. Or purchase the software and you will have a license that does not expire.
Your toolkit is essentially a subscription. When that subscription expires, you can no longer use that software.
OG
Good day! I would like to ask how to reset my activation since i changed the whole computer where the previous license was installed. But when...
6,586
Yesterday i bought notebook hp compaq 6910p (its a old but great machine ) which used WinXp a Pcmcia slot for my 1784-pcmk/b card. I need install...
33,429
We bought rslogix 500. I understand I can only use it on one computer at time but want to be able to mess around with programming on my pc and...
18
11,160
Hi guys, just want to check with you before calling AB, maybe someone knows. Can I just buy the serial and activation key for the old software? I...
2,789
I am considering to buy Rslogix 500 Standard (V6.0 or V7.0) through Ebay. What can I do if activation key on hard disk drive is damaged one day or...
7,254
