RSLogix 500 Scale Function Test
Thank you, Mickey for the further explanation.
May I know how to figure out the raw data value related with the voltage and resistor that have been chosen.
These raw data value will be the input min and max, right?
May I know how you come out with the value of raw date value.
Is these the value for the input min and input max?
As stated above the raw data for 0-10v input for the embedded analog input for the ML1400 is 0-4095.
1.88/10=.188
.188*4095=770
9.4/10=.94
.94*4095=3849
So using the "SCP" instruction and assuming the value of your resistor is exactly 470 ohms, then
Input min=770
Input Max=3849
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
104
I have a little bit of experience with Allen-Bradley. I have a Micrologix 1500 (RSLogix 500) and a PanelView Plus 7 (FactoryTalk View Studio ME)...
198
buen dia. tengo una falla al pasar los tags de mi plc SLC 5 0/4 a mi panel me aparece un error Problem writing value " " to item <tag name>...
97
Will someone please convert this logic to pdf?
142
Hello, Haven't been on in a while. I need to generate a bit level pdf of the I/O for RSLogix 500. I can generate a report but it just shows the...
173
