RSLogix 5000 - Can't delete programs
Adam Bullen
May 2012
Taupo
I have moved some programs from the tasks to the unscheduled programs / phases. All the code is deleted from the programs; all the tags have been removed. The delete option is active but when I try to delete the program I get the message:
"Failed to delete the program, "delete", Program / phase contains one or more tags"
This is very annoying; I have deleted a bunch of other programs but three are being stubborn. Nothing is showing up in the cross reference for the program.
Is there any way to check what is still referencing a program so I can get rid of it to be able to delete the programs.
For back ground I am splitting a program across two PLC's since the CPU is overloaded and there is a project to add a bunch more stuff to that plant area. So I started with the same code on both and split the code across the logical place in the plant. I am left with the ghosts of some old programs.
That works, which is great. But it requires a download since the files are not the same after exporting to a L5X. If I had more time I could verify the code was correct.
Hello everyone. I want to do a mass-deletion of tags in a PLC program. I want to know if I can create a .csv import file containing the tag...
3,061
Howdy, I am using RSLogix 5000 Version 20.01, and I have written a simple program that does what it is supposed to. Now I want to clean it up...
9,518
I faced a problem with sudden crash of my pc while I was doing some online chsnges in rslogix 5000 plc. After restarting pc and reconnecting with...
7,958
was wondering how to delete search/find history in rslogix5000 as it tends to be long after searching a few tags. thanks in advance
1,579
Hi, I'm trying to delete the tasks as shown in the picture attached, but I am not having success. I looked at some articles on this forum and...
25
41,417
