RSLogix 5000 Use Import Tool to Delete Tags
Paul Rousseau
Dec 2014
Calgary
Hello everyone.
I want to do a mass-deletion of tags in a PLC program. I want to know if I can create a .csv import file containing the tag names I want to delete, then use the "Tools -> Import -> Tags and Logic Comments" utility to delete them. This tool is great for tag/alias/comment modifications and additions, but can it do tag/alias deletions? If it can do tag/alias deletions, what is the record format required in the .csv file?
For example,
TYPE SCOPE NAME DESCRIPTION DATATYPE SPECIFIER ATTRIBUTES
TAG MyTag "This is a tag" REAL
ALIAS MyAlias "This is an alias" MyTag
will add or modify the tag, MyTag and alias, MyAlias. How would I go about making .csv entries to delete MyTag and MyAlias?
Thank you.
I don't know a way to delete tags when importing a csv database file. My experience is that existing tags are ignored if the tag does not appear in the import file and are only overwritten if the tag exists in the import file and 'overwrite' is selected.
You may find a workaround by creating a new project then importing logic from your original. You can copy and paste or create export file(s). This may be easier than searching for and manually deleting specific tags.
You won't be able to delete them via CSV file.
Why don't you just delete them in the tag editor? You can easily filter your tags in the editor, then select all --> delete.
Hey all, I am trying to figure out how to import some alarm messages without having to type them all in by hand. They are in the format of an...
1,127
Hi all, I am in the process of a phased conversion from PLC5 to CLX. I'm trying to automate the process of finding and replacing tags/comments...
3,870
Out of the blue my RSLogix locks up on trying to import a Routine or AOP into my Controllogix logic. A few months ago I was swapping logic...
20
14,997
Is there anyway I can use a spreadsheet to update tag values and Import them into RSLogix 5000? I.E. if i were to create a tag with the...
21
54,593
Hi All, Does someone know how to export tags in RSLogix 5000 modify their names and import again without losing references in the logic? In...
65,332
