RSLogix 5000 file saving
plcstu1980
Oct 2010
27
Hi, i'm having trouble saving a project (.ACD) with a number a the front. It says it is an invalid file name, but i've saved my files previously with numbers at the front. Anyone know what the issue is here?
Thanks, Stu
Rockwell say:
Failed to save project in RSLogix 5000 753-80042029
493386 | Date Created: 06/05/2012 | Last Updated: 07/03/2015
RSLogix 5000 reports error 753-80042029 during attempting to "save" or "save as" ACD file
Answer
Go to File -> Save as
Change project name and project type to L5K
Hit Save
Close project
Open the L5K file and import project
Save ACD file
also....
Project name is invalid.
RSLogix 5000 software uses IEC-1131 Name Standard. It covers the following requirements:
minimum of six characters (Logix Designer application supports a minimum of 1 character)
starting with an underscore “_” or an alpha character (A-Z)
followed by one or more characters consisting of an underscore “_”, alpha character (A-Z) or a number (0-9)
spaces can not be used
Rockwell say:
Answer
Hit Save
Close project
Save ACD file
also....
Thank you very much (y) need to remember myself about the error codes, so i can ask next time. Will also help a few other people i know (y) Update: it seems its the project name is invalid, so even importing the project still needs a save as name. So will have to rename the project at the end to company naming convention. But at least i can let people know whats up
I remember having this issue, i believe you can name a file that begins with a number BUT you cannot create it that way.
e.g. Create a new project & save as new project. Find your new project.acd file and rename to 2016Customerx.acd
Ash
Ash
Hi, exact same problem here. People know about at work, but no one told me :confused:
How can I open a file that says "The requested resource is not recognized by the Security Authority. See your Security Administrator."
2,245
Greetings all, I have a programming unit that is not allowed to be online. ( yes, we are remaining at the ready for a Cylon attack) It is rslogix...
1,258
Hi Everyone, I have a problem that I could not get any results as a result of my research on the web. I installed RSLogix 5000 pro edt. (v13.04...
3,259
I'm working on a retrofit job, it is using a Control Logix L55, Ver 13, with Devicenet IO and Ultra 3K drives on Devicenet. Now I need to add in...
8,459
Dear All, I want to ask about converting Status File from RSLogix 5 to RSLogix 5000. I know that RSLogix 5000 have no "status file" function on...
3,154
