Hi Drew
I have used both PLCs and prefer the Omron for fast software development, processor speed, function list etc etc.
You can have the software automatically allocate bits for you but you do not have to. You can allocate all bits yourself in the normal way. This is the way I work. The software, Cx-Programmer, is symbol based. This can be a pain at times but the BIG advantage is that if you wish to change a symbol to a different I/O number, you change it in the symbol editor and it automatically changes all the references in the program. If you go the Omron way, I would suggest you use global symbols not local symbols. European idea and if you do not have it selling PLCs in Europe is becoming harder and harder.
The CS1 is an absolute rocket ship, particularly the high end processors, and has a mind blowing function list. I like that because it saves me writing a lot of code. Omron also have 96 bit input and output cards available for the beast. Saves racks, space and money.
Suggest you have a look at the Omron CJ1. It has the same processors as the CS1 but has no rack, mounts on a din rail, and the modules are about the size of a cigarette packet. Same function list and all. Because of the size, I/O blocks are limited to 64 bits and it would be impossible to increase the density above that level.
They both have huge areas of internal relays and registers as well, dependant on the processor you choose. If you are looking for a platform that has high end and low end processors, the CJ1 is the way to go. High and low end have the same instruction set etc. No need to try to remember waht you have available from processor to processor. The low end CJ1 is also very inexpensive.
Might I suggest you join up and not remain a guest.
beerchug
beerchug
