I'm really bugged with this. The CPT instruction in below rung apparently generates the following program fault:
If I disable the CPT instruction (with tempint0.0), all goes well. If it's enabled the Program fault is generated. CLXPort.SplitPos is either 0 or 68 the other DINT is always 2. I really don't understand why adding these 2 DINT is generating this fault. This seems so simple straight forward.
Any help is really appreciated.
Thank you.
B.
(Type 04) Program Fault
(Code 56) Invalid Start and/or Quantity value.
Task: MainTask
Task: MainTask
Thank you.
B.
